Accessories
Motorola Signal Booster: VHF/UHF/HDTV/Cable TV Amplifier
By Joe Lozito
2007-11-27 23:01:00
As you may have guessed from perusing Big Picture Big Sound, I enjoy watching TV. With a 1080p projector, and a 100-inch screen, you just get sucked right into the action. Further, I think Digital Video Recorders (DVRs or TiVOs) are the best thing to happen to TV since coaxial cable. So imagine my dismay when my recorded shows began to sputter and distort - as though the files were corrupted. It would typically occur before or after commercial breaks, the picture would freeze, pixilate, audio would drop out and then resume several seconds later - usually making me miss important lines of dialogue ("The murderer is...[[sputter, sputter]]." You get the idea.)
Since DVRs are effectively just large hard drives inside a cable box, I figured something was wrong with mine. After two visits from my cable guy and two replacement boxes, the problem persisted. My cable provider (to remain nameless) was at a loss. "It must be something with the line outside the building," was the straw they grasped at, leaving me relegated to the unsolved mysteries category.
To me, it seemed like the cable signal was weak, so I invested a little under $40 in a Motorola Signal Booster. The simple little device plugs into the wall and has one input for your cable feed and one output, which I connected to a splitter which feeds my cable box and cable modem.
It's important to put the booster as close to the source as possible (i.e., connected directly to the main cable or antenna wire coming into your house) so the booster amplifies the signal and not the additional noise that can be introduced by splitters. Any splitters should be of high quality and should be inserted after the booster for best effect. Also, if you have a cable modem or plan to watch Video-On-Demand or Pay-Per-View, you'll need a bi-directional (two-way) amplifier so it can pass the return feed from the cable box and cable modem. The Motorola is just such a device.
After installing the booster and recording several shows, I only noticed one slight skip (and it was during "Robot Chicken," so who cares?) out of about ten recorded tests. Over the last couple of weeks the amount of drop-outs and pixilation I've seen on both live and recorded HDTV has dropped significantly, with no additional noise or distortion introduced by the amplifier. The signal booster really seems to have made a difference - and just in time for the writer's strike. D'oh!
The booster is available with a single input/output (as reviewed) or in a 2-port or 4-port version.  The only difference being that the 2-port version has two outputs and the 4-port version has four outputs, so you will not need to buy a separate splitter to use this with multiple TVs or one TV and a cable modem.
If you just can't get a solid signal on your cable box or cable modem and your cable company is giving you the runaround, give this little booster a shot. It made a world of difference for me.
[editor's note: if you are having trouble receiving DTV channels from an antenna, connecting your antenna directly to your TV, this product will most likely not solve your problem.  Instead you may need a better antenna or an antenna preamp, or you may even need to mount your antenna outside for the best reception.  This cable booster is primarily useful in being able to split a cable TV and modem signal out to multiple devices with minimal loss and for boosting the strength of borderline CATV signals].
Features/Specifications:
  • Model #: 484095-001-00
  • Full bandwidth, bi-directional amplifier
  • Capable of both forward and return (two-way) communications - important for cable modem services
  • Improves UHF/VHF/FM antenna reception
  • Improve signal strength up to 32 times (15 dB)
  • Low noise figure of only 2.5 dB
  • Supports Pay-per-view and Video on Demand (VOD) Services
  • Housing Dimensions: 4.0H x 4.9W x 1.1D in. (10.2 x 12.4 x 2.8 cm)
  • Weight: 1.7lb (0.8 kg)
What's in the Box?
  • One amplifier
  • One AC adapter
  • Two six-foot coax connections
  • Two mounting screws
  • One installation guide
Motorola, Inc.
1303 East Algonquin Road
Schaumburg, Illinois 60196 USA
Telephone: +1 847 576 5000
Web site: www.motorola.com
Top of Page
